Introducción
This guide instructs you on how to replace/remove the back cover of the Dell XPS 15 9575 in order to access the internal components.
Use caution when undoing the clips that hold the cover to the case so that the laptop is secure after reassembly.
Qué necesitas
Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
