Saltar al contenido principal
Dell XPS 15 9570 Wireless Card Replacement
Qué necesitas
  1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: paso 1, imagen 1 de 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Wireless Card Replacement: paso 2, imagen 1 de 3 Dell XPS 15 9570 Wireless Card Replacement: paso 2, imagen 2 de 3 Dell XPS 15 9570 Wireless Card Replacement: paso 2, imagen 3 de 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Wireless Card Replacement: paso 3, imagen 1 de 2 Dell XPS 15 9570 Wireless Card Replacement: paso 3, imagen 2 de 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Wireless Card Replacement: paso 4, imagen 1 de 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: paso 5, imagen 1 de 2 Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: paso 5, imagen 2 de 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  6. Dell XPS 15 9570 Wireless Card Replacement: paso 6, imagen 1 de 1
    • Lift the wireless card bracket off of the wireless card.
  7. Dell XPS 15 9570 Wireless Card Replacement: paso 7, imagen 1 de 2 Dell XPS 15 9570 Wireless Card Replacement: paso 7, imagen 2 de 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  8. Dell XPS 15 9570 Wireless Card Replacement: paso 8, imagen 1 de 1
    • Carefully remove the wireless card.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 10
Ultimos 30 días: 34
Todo El Tiempo: 2,689
