Saltar al contenido principal
Dell XPS 15 9570 Heat Sink Replacement
Qué necesitas
  1. Dell XPS 15 9570 Heat Sink Replacement, Base Cover: paso 1, imagen 1 de 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Heat Sink Replacement: paso 2, imagen 1 de 3 Dell XPS 15 9570 Heat Sink Replacement: paso 2, imagen 2 de 3 Dell XPS 15 9570 Heat Sink Replacement: paso 2, imagen 3 de 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Heat Sink Replacement: paso 3, imagen 1 de 2 Dell XPS 15 9570 Heat Sink Replacement: paso 3, imagen 2 de 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Heat Sink Replacement: paso 4, imagen 1 de 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Heat Sink Replacement, Battery: paso 5, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Heat Sink Replacement: paso 6, imagen 1 de 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Heat Sink Replacement: paso 7, imagen 1 de 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: paso 8, imagen 1 de 2 Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: paso 8, imagen 2 de 2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Heat Sink Replacement: paso 9, imagen 1 de 1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 37
Todo El Tiempo: 2,768
