Saltar al contenido principal
Dell XPS 15 9570 Fan Replacement
Qué necesitas
  1. Dell XPS 15 9570 Fan Replacement, Base Cover: paso 1, imagen 1 de 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Fan Replacement: paso 2, imagen 1 de 3 Dell XPS 15 9570 Fan Replacement: paso 2, imagen 2 de 3 Dell XPS 15 9570 Fan Replacement: paso 2, imagen 3 de 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Fan Replacement: paso 3, imagen 1 de 2 Dell XPS 15 9570 Fan Replacement: paso 3, imagen 2 de 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Fan Replacement: paso 4, imagen 1 de 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Fan Replacement, Battery: paso 5, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Fan Replacement: paso 6, imagen 1 de 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Fan Replacement: paso 7, imagen 1 de 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Fan Replacement, Fan: paso 8, imagen 1 de 2 Dell XPS 15 9570 Fan Replacement, Fan: paso 8, imagen 2 de 2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  9. Dell XPS 15 9570 Fan Replacement: paso 9, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  10. Dell XPS 15 9570 Fan Replacement: paso 10, imagen 1 de 2 Dell XPS 15 9570 Fan Replacement: paso 10, imagen 2 de 2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  11. Dell XPS 15 9570 Fan Replacement: paso 11, imagen 1 de 1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 42
Ultimos 30 días: 112
Todo El Tiempo: 6,342
