Saltar al contenido principal
Dell XPS 15 9560 Solid State Drive (SSD) Replacement
Qué necesitas
  1. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Back Panel: paso 1, imagen 1 de 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: paso 2, imagen 1 de 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: paso 3, imagen 1 de 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: paso 4, imagen 1 de 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): paso 5, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  6. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: paso 6, imagen 1 de 1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  7. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: paso 7, imagen 1 de 1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
Conclusión
Una persona más ha completado esta guía.
Equipo
Clemson, Team 4-5, Hunter Fall 2021 Miembro de Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 41
Todo El Tiempo: 2,843
