Saltar al contenido principal
Dell XPS 15 9560 Motherboard Replacement
Qué necesitas
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Motherboard Replacement: paso 2, imagen 1 de 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Motherboard Replacement: paso 3, imagen 1 de 1
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Motherboard Replacement: paso 4, imagen 1 de 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Motherboard Replacement, Battery: paso 5, imagen 1 de 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  6. Dell XPS 15 9560 Motherboard Replacement: paso 6, imagen 1 de 1
    • Unplug the battery cable.
  7. Dell XPS 15 9560 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the battery.
  8. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: paso 8, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  9. Dell XPS 15 9560 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  10. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): paso 10, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: paso 11, imagen 1 de 1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  12. Dell XPS 15 9560 Motherboard Replacement: paso 12, imagen 1 de 1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  13. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: paso 13, imagen 1 de 1
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  14. Dell XPS 15 9560 Motherboard Replacement: paso 14, imagen 1 de 1
    • Disconnect the wireless card cables from the wireless card.
  15. Dell XPS 15 9560 Motherboard Replacement: paso 15, imagen 1 de 1
    • Slide the wireless card out of its slot.
  16. Dell XPS 15 9560 Motherboard Replacement, Fans: paso 16, imagen 1 de 1
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  17. Dell XPS 15 9560 Motherboard Replacement: paso 17, imagen 1 de 1
    • Unplug the fan cable.
  18. Dell XPS 15 9560 Motherboard Replacement: paso 18, imagen 1 de 1
    • Carefully remove the left-side fan.
  19. Dell XPS 15 9560 Motherboard Replacement: paso 19, imagen 1 de 1
  20. Dell XPS 15 9560 Motherboard Replacement: paso 20, imagen 1 de 1
    • Remove the right-side fan.
  21. Dell XPS 15 9560 Motherboard Replacement, RAM: paso 21, imagen 1 de 2 Dell XPS 15 9560 Motherboard Replacement, RAM: paso 21, imagen 2 de 2
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  22. Dell XPS 15 9560 Motherboard Replacement, Motherboard: paso 22, imagen 1 de 1
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  23. Dell XPS 15 9560 Motherboard Replacement: paso 23, imagen 1 de 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  24. Dell XPS 15 9560 Motherboard Replacement: paso 24, imagen 1 de 1
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  25. Dell XPS 15 9560 Motherboard Replacement: paso 25, imagen 1 de 1
    • Remove the motherboard.
Conclusión
Una persona más ha completado esta guía.
Jada Houser
Miembro Desde 09/28/21
839 Reputación
7 Guías creadas
Equipo
Clemson, Team 4-5, Hunter Fall 2021 Miembro de Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 19
Ultimos 30 días: 53
Todo El Tiempo: 4,385
