Saltar al contenido principal
Dell XPS 15 9530 WiFi Card Replacement
Qué necesitas
  1. Dell XPS 15 9530 WiFi Card Replacement, Base Cover: paso 1, imagen 1 de 3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: paso 1, imagen 2 de 3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: paso 1, imagen 3 de 3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 WiFi Card Replacement: paso 2, imagen 1 de 2 Dell XPS 15 9530 WiFi Card Replacement: paso 2, imagen 2 de 2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 WiFi Card Replacement: paso 3, imagen 1 de 1
    • Lift the lower case off.
  4. Dell XPS 15 9530 WiFi Card Replacement, WiFi Card: paso 4, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the screw holding the WiFi card down. Be careful not to lose the metal retainer holding the antenna cables down.
    • Without applying too much force, pop out the antenna cables and remove the card.
    • Insert the new card, and reattach the antenna cables. The black cable connects to the main antenna slot (marked with a solid triangle) and the white connects to the auxiliary (marked with an empty triangle).
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 46
Todo El Tiempo: 2,111
