Saltar al contenido principal
Introducción
How to replace the 2.5" hard drive of a Dell XPS 15 9530.
Partes
No se especificaron partes.
  1. After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
  3. Remove the screws that secure the battery to the palm-rest assembly.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery off the palm-rest assembly.
    • After you remove the battery, turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
  4. CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the palm-rest assembly.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
    • Lift the hard-drive assembly off the palm-rest assembly.
  5. Disconnect the interposer from the hard-drive assembly.
    • Disconnect the interposer from the hard-drive assembly.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
    • Lift the hard drive off the hard-drive bracket.
Conclusión
To reassemble your device, follow these instructions in reverse order with the replacement hard drive.
2 personas más completaron esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
36,011 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 10
Últimos 30 Días: 37
Todo El Tiempo: 883
