Saltar al contenido principal
Introducción
How to replace the battery of a Dell XPS 15 9530.
Partes
No se especificaron partes.
  1. After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
  4. Remove the screws that secure the battery to the palm-rest assembly.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery off the palm-rest assembly.
    • After you remove the battery, turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
Conclusión
2 personas más completaron esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 16
Últimos 30 Días: 83
Todo El Tiempo: 1,762
