Saltar al contenido principal
Dell XPS 15 9510 SSD Replacement
Qué necesitas
  1. Dell XPS 15 9510 SSD Replacement, Lower Case: paso 1, imagen 1 de 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 SSD Replacement: paso 2, imagen 1 de 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 SSD Replacement: paso 3, imagen 1 de 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 SSD Replacement, SSD: paso 4, imagen 1 de 2 Dell XPS 15 9510 SSD Replacement, SSD: paso 4, imagen 2 de 2
    • Remove the single screw from the left side of the SSD using a Phillips #00 screwdriver.
    • The SSD is spring-released; it will pop up after removing the screw.
  5. Dell XPS 15 9510 SSD Replacement: paso 5, imagen 1 de 1
    • Use your fingers to carefully remove the SSD from the laptop.
Conclusión
3 personas más completaron esta guía.
Austin Sa
Miembro Desde 03/30/22
432 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 51
Todo El Tiempo: 4,321
