Saltar al contenido principal
Dell XPS 15 9500 Speaker Replacement
Qué necesitas
  1. Dell XPS 15 9500 Speaker Replacement, Base Panel: paso 1, imagen 1 de 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Speaker Replacement: paso 2, imagen 1 de 2 Dell XPS 15 9500 Speaker Replacement: paso 2, imagen 2 de 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 3.0 mm screws (one on each speaker).
    • Use an opening tool to lift out the speaker.
  4. Dell XPS 15 9500 Speaker Replacement: paso 4, imagen 1 de 2 Dell XPS 15 9500 Speaker Replacement: paso 4, imagen 2 de 2
    • Use an opening tool to push the left speaker's cable out of its port until it is disconnected.
    • The speaker on the right side isn't connected to the motherboard, and is only connected to the left speaker by a wire at the bottom.
Conclusión
Bryan Chung
Miembro Desde 10/18/19
437 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 859
