Saltar al contenido principal
Dell XPS 15 9500 SSD Replacement
Qué necesitas
  1. Dell XPS 15 9500 SSD Replacement, Base Panel: paso 1, imagen 1 de 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 SSD Replacement: paso 2, imagen 1 de 2 Dell XPS 15 9500 SSD Replacement: paso 2, imagen 2 de 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 SSD Replacement, SSD: paso 3, imagen 1 de 1
    • Use a Phillips #000 screwdriver to remove the single 3.0 mm screw on the right side of the SSD.
  4. Dell XPS 15 9500 SSD Replacement: paso 4, imagen 1 de 1
    • Lift the card a few millimeters, then pull it directly out of its slot.
  5. Dell XPS 15 9500 SSD Replacement: paso 5, imagen 1 de 2 Dell XPS 15 9500 SSD Replacement: paso 5, imagen 2 de 2
    • If you wish to install a second SSD, there is an empty slot for an additional SSD underneath the copper cover. If you're just replacing the existing SSD, stop here.
    • Use a Phillips #000 screwdriver to remove the one 3.0 mm screw on the left side of the SSD slot.
    • Pull the cover out directly toward the left.
Conclusión
Bryan Chung
Miembro Desde 10/18/19
437 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 21
Ultimos 30 días: 84
Todo El Tiempo: 4,801
