Saltar al contenido principal
Dell XPS 14Z L412Z LCD Screen Glass Replacement
Qué necesitas
  1. Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: paso 1, imagen 1 de 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: paso 1, imagen 2 de 2
    • Using the iFixit opening tools, carefully pry up the trim around the screen.
    • It is recommended to start in a corner.
  2. Dell XPS 14Z L412Z LCD Screen Glass Replacement: paso 2, imagen 1 de 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: paso 2, imagen 2 de 2
    • Using a heat gun, carefully apply heat evenly across the glass.
  3. Dell XPS 14Z L412Z LCD Screen Glass Replacement: paso 3, imagen 1 de 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: paso 3, imagen 2 de 2
    • Using the iFixit opening tools, carefully pry the glass off the screen.
    • This is glass and will shatter if too much force is used.
Conclusión
Colton Niewolny
Miembro Desde 02/15/18
411 Reputación
4 Guías creadas
Equipo
UW Stout, Team S8-G3, Ogden Spring 2018 Miembro de UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Miembros
6 Guías creadas
Un comentario
to remove the black cover, use the rod of a pen pen cap. Spread both sides while pressing the top of the black cover (towards the inside of the screen). Must a little force.The closure mechanism is composed of two things that alternate every 2 cm: 1 clips that is sinking on the gray part (you have to lift the black part towards the right to take it out) then 1 rod that comes down in underneath (just stand aside - neither lift nor lower to remove)
wiwi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 2,119
