Saltar al contenido principal
Dell XPS 14Z L412Z Hard Drive Replacement
Qué necesitas
  1. Dell XPS 14Z L412Z Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Hard Drive Replacement: paso 2, imagen 1 de 2 Dell XPS 14Z L412Z Hard Drive Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Locate the hard drive on the bottom right corner.
    • Unscrew the three 3.5mm screws with the Phillips #0 screwdriver.
  4. Dell XPS 14Z L412Z Hard Drive Replacement: paso 4, imagen 1 de 1
    • Remove the four additional 3.5mm screws using the Phillips #0 screwdriver.
  5. Dell XPS 14Z L412Z Hard Drive Replacement: paso 5, imagen 1 de 1
    • Carefully pull and remove the old hard drive.
Conclusión
Colton Niewolny
Miembro Desde 02/15/18
411 Reputación
4 Guías creadas
Equipo
UW Stout, Team S8-G3, Ogden Spring 2018 Miembro de UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Miembros
6 Guías creadas
Un comentario
On my laptop there was a small curved metal bracket that sat in the very corner of the PC covering one corner of the hard drive. That had to be removed by loosening a screw and gently prying the bar out before the hard drive could be removed.
dude - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 1,550
