Saltar al contenido principal
Dell XPS 14Z L412Z Battery Replacement
Qué necesitas
  1. Dell XPS 14Z L412Z Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Battery Replacement: paso 2, imagen 1 de 2 Dell XPS 14Z L412Z Battery Replacement: paso 2, imagen 2 de 2
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Battery Replacement, Battery: paso 3, imagen 1 de 1
    • The battery is on the bottom left side.
  4. Dell XPS 14Z L412Z Battery Replacement: paso 4, imagen 1 de 1
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  5. Dell XPS 14Z L412Z Battery Replacement: paso 5, imagen 1 de 2 Dell XPS 14Z L412Z Battery Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
Conclusión
4 personas más completaron esta guía.
Colton Niewolny
Miembro Desde 02/15/18
411 Reputación
4 Guías creadas
Equipo
UW Stout, Team S8-G3, Ogden Spring 2018 Miembro de UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Miembros
6 Guías creadas
Un comentario
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 2,907
