Introducción
The cooling fan is the main source of cooling for the device. It prevents overheating which can cause internal damage to the device such as the hard drive. It is highly important to have a clean and functioning cooling fan. Much of the cabling is delicate in this part of the computer. Be careful not to destroy connections to the motherboard. This guide will show you how to replace a cooling fan. You will need tweezers, a Phillips #0 screwdriver, and a plastic opening tool.
Qué necesitas
Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
The fan is located on the upper right hand side of the laptop.
Unscrew the four 4.5mm Phillips #0 screws along the fan.
