Saltar al contenido principal
Dell XPS 14 L401X Hard Drive Replacement
Qué necesitas
  1. Dell XPS 14 L401X Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Dell XPS 14 L401X Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X Hard Drive Replacement, RAM: paso 2, imagen 1 de 3 Dell XPS 14 L401X Hard Drive Replacement, RAM: paso 2, imagen 2 de 3 Dell XPS 14 L401X Hard Drive Replacement, RAM: paso 2, imagen 3 de 3
    • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
    • The captive screws will not come off of the panel.
    • Pull the panel upwards and towards the battery to remove.
    • Put the panel to the side, exposing the RAM.
  3. Dell XPS 14 L401X Hard Drive Replacement: paso 3, imagen 1 de 2 Dell XPS 14 L401X Hard Drive Replacement: paso 3, imagen 2 de 2
    • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
    • Keep your fingers on the edge of the chip.
    • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
  4. Dell XPS 14 L401X Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 Dell XPS 14 L401X Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
  5. Dell XPS 14 L401X Hard Drive Replacement: paso 5, imagen 1 de 2 Dell XPS 14 L401X Hard Drive Replacement: paso 5, imagen 2 de 2
    • Push the hard drive to the right with a spudger to unseat it from its socket while pulling out the hard drive with your other hand.
  6. Dell XPS 14 L401X Hard Drive Replacement: paso 6, imagen 1 de 3 Dell XPS 14 L401X Hard Drive Replacement: paso 6, imagen 2 de 3 Dell XPS 14 L401X Hard Drive Replacement: paso 6, imagen 3 de 3
    • Use a JIS 1 screwdriver to remove (1) 2.5mm screw attaching the plastic cosmetic cover to the hard drive.
    • Detach the plastic cosmetic cover from the hard drive.
    • This cosmetic cover will be transferred to the new hard drive.
Conclusión
Nicole Johnson
Miembro Desde 10/19/17
428 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team S4-G3, Julie Fall 2017 Miembro de UMass Dartmouth, Team S4-G3, Julie Fall 2017
UMASSD-JULIE-F17S4G3
3 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,292
