Saltar al contenido principal
Dell XPS 14 L401X Battery Replacement
Qué necesitas
  1. Dell XPS 14 L401X Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell XPS 14 L401X Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Mark
Miembro Desde 10/19/17
643 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team S4-G3, Julie Fall 2017 Miembro de UMass Dartmouth, Team S4-G3, Julie Fall 2017
UMASSD-JULIE-F17S4G3
3 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 692
