Remove the battery by sliding the battery lock switch
  • Remove the battery by sliding the battery lock switch
Agregar Comentario
Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
Agregar Comentario
  • Remove two screws which holds a smaller back panel covering only the heatsink
Agregar Comentario
  • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
  • Now carefully lift the unit from holding the heat pipe.
  • After the heat-pipe unit is removed, the power connector for the fan is accessible.
Agregar Comentario
  • First remove the power connector for the CPU Fan.
  • Now remove the two screws connecting the CPU Fan.
  • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
Agregar Comentario
  • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
Agregar Comentario
  • Follow all step backwards and finish.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Paras Tolani
Miembro Desde 01/03/13
188 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 9
Todo El Tiempo: 2,138
