Saltar al contenido principal
Dell XPS 13 L321X Mouse pad Replacement
Qué necesitas
  1. Dell XPS 13 L321X Mouse pad Replacement, Track Pad: paso 1, imagen 1 de 2 Dell XPS 13 L321X Mouse pad Replacement, Track Pad: paso 1, imagen 2 de 2
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Mouse pad Replacement: paso 2, imagen 1 de 2 Dell XPS 13 L321X Mouse pad Replacement: paso 2, imagen 2 de 2
    • Disconnect the ribbon cable with a plastic iFixit opening tool, by lifting up the black clip and by pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Mouse pad Replacement: paso 3, imagen 1 de 1
    • With a plastic iFixit opeing tool, insert it in between and remove the battery cable.
  4. Dell XPS 13 L321X Mouse pad Replacement: paso 4, imagen 1 de 2 Dell XPS 13 L321X Mouse pad Replacement: paso 4, imagen 2 de 2
    • Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
  5. Dell XPS 13 L321X Mouse pad Replacement: paso 5, imagen 1 de 1
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and by pulling the white ribbon.
    • Place aside.
  6. Dell XPS 13 L321X Mouse pad Replacement: paso 6, imagen 1 de 3 Dell XPS 13 L321X Mouse pad Replacement: paso 6, imagen 2 de 3 Dell XPS 13 L321X Mouse pad Replacement: paso 6, imagen 3 de 3
    • Remove four 2mm screws with a PH00 screwdriver.
    • Remove the mouse pad.
Linea de Meta
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S6-G3, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 811
