Saltar al contenido principal
Dell XPS 13 L321X Battery Replacement
Qué necesitas
  1. Dell XPS 13 L321X Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell XPS 13 L321X Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Battery Replacement: paso 2, imagen 1 de 2 Dell XPS 13 L321X Battery Replacement: paso 2, imagen 2 de 2
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Battery Replacement: paso 3, imagen 1 de 1
    • Insert a plastic iFixit opening tool in between the port and the wires to remove the battery cable.
  4. Dell XPS 13 L321X Battery Replacement: paso 4, imagen 1 de 2 Dell XPS 13 L321X Battery Replacement: paso 4, imagen 2 de 2
    • Take out 8 silver screws that are holding the battery with a PH00 head screwdriver.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
Linea de Meta
6 personas más completaron esta guía.
Equipo
USF Tampa, Team S6-G3, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 2,608
