Saltar al contenido principal
Dell XPS 12 9Q23 Battery Replacement
Qué necesitas
  1. Dell XPS 12 9Q23 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Battery Replacement: paso 2, imagen 1 de 1
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Battery Replacement: paso 3, imagen 1 de 1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Battery Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Battery Replacement, Remove the battery: paso 5, imagen 1 de 1
    • Once all the screws have been removed the battery is now safe to extract
Conclusión
5 personas más completaron esta guía.
2 comentarios
Any tips for registering the new battery in the BIOS?
Ryan Porter - Contestar
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
https://fr.ifixit.com/R%C3%A9ponses/Devi...
Schwarzer -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 26
Todo El Tiempo: 4,535
