Partes
No se requieren partes.
  1. Turn the tablet over. Remove the screws that secure the back-cover assembly to the display assembly.
    • Turn the tablet over.
    • Remove the screws that secure the back-cover assembly to the display assembly.
    • Using a plastic scribe, pry up along the edges of the back-cover assembly.
    • Carefully, lift the back-cover assembly and turn it over.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the screws that secure the battery to the back-cover assembly.
    • Remove the screws that secure the battery to the back-cover assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery, along with its cable, off the back-cover assembly.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Remove the screw that secures the solid-state drive to the back-cover assembly.
    • Remove the screw that secures the solid-state drive to the back-cover assembly.
    • Lift and slide the solid-state drive off the back-cover assembly.
Linea de Meta
Johnathan Hammond
Miembro Desde 28/02/18
35,756 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 24
Todo El Tiempo: 345
