Saltar al contenido principal
Dell XPS 10 Front and Rear Camera Replacement
Qué necesitas
  1. Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: paso 1, imagen 1 de 3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: paso 1, imagen 2 de 3 Dell XPS 10 Front and Rear Camera Replacement, Front and Rear Camera: paso 1, imagen 3 de 3
    • Unscrew the two screws shown circled in red in the picture.
    • Use a #0 Phillips screwdriver to remove the two 4 mm screws
    • Lift up the plug that connects the camera to the motherboard using the plastic opening tool as shown in the pictures.
  2. Dell XPS 10 Front and Rear Camera Replacement: paso 2, imagen 1 de 2 Dell XPS 10 Front and Rear Camera Replacement: paso 2, imagen 2 de 2
    • After the rear facing camera is removed, you may now remove the front facing camera.
    • Use the nylon spudger to disconnect the cable on the motherboard.
    • Make sure you use the black plastic spudger to pry up the aluminum tape holding the front facing camera. Be careful as the tape is fragile.
Conclusión
James
Miembro Desde 10/04/16
401 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-1, Nance Fall 2016 Miembro de USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 308
