Saltar al contenido principal
Dell XPS 10 Battery Replacement
Qué necesitas
  1. Dell XPS 10 Battery Replacement, Battery: paso 1, imagen 1 de 3 Dell XPS 10 Battery Replacement, Battery: paso 1, imagen 2 de 3 Dell XPS 10 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 Battery Replacement: paso 2, imagen 1 de 3 Dell XPS 10 Battery Replacement: paso 2, imagen 2 de 3 Dell XPS 10 Battery Replacement: paso 2, imagen 3 de 3
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
Conclusión
2 personas más completaron esta guía.
saraspam
Miembro Desde 09/28/16
244 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-1, Nance Fall 2016 Miembro de USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 3,149
