Saltar al contenido principal
Dell Wyse Xn0m Mouse Sensor Board Replacement
Qué necesitas
  1. Dell Wyse Xn0m Mouse Sensor Board Replacement, Mouse Sensor Board: paso 1, imagen 1 de 1
    • Flip the device over. Unscrew nine marked 7mm Phillips #1 screws.
  2. Dell Wyse Xn0m Mouse Sensor Board Replacement: paso 2, imagen 1 de 2 Dell Wyse Xn0m Mouse Sensor Board Replacement: paso 2, imagen 2 de 2
    • Remove the keyboard by pushing back the tabs at the marked locations with a spudger or plastic opening tool.
  3. Dell Wyse Xn0m Mouse Sensor Board Replacement: paso 3, imagen 1 de 2 Dell Wyse Xn0m Mouse Sensor Board Replacement: paso 3, imagen 2 de 2
    • Turn the device around so the screen is closest to you. Lift the keyboard and detach the ribbon cable with the spudger.
    • To disconnect the cable, disengage the locking tab of the ZIF connector with the spudger and pull the cable out gently.
  4. Dell Wyse Xn0m Mouse Sensor Board Replacement: paso 4, imagen 1 de 1
    • Remove the keyboard and set it aside. Detach the other ribbon cables with the spudger.
    • Remove five 8mm Phillips #1 screws.
  5. Dell Wyse Xn0m Mouse Sensor Board Replacement: paso 5, imagen 1 de 1
    • Pry open the laptop with the plastic opening tool.
  6. Dell Wyse Xn0m Mouse Sensor Board Replacement: paso 6, imagen 1 de 2 Dell Wyse Xn0m Mouse Sensor Board Replacement: paso 6, imagen 2 de 2
    • Under the trackpad, detach the ribbon cables with the spudger.
    • Unscrew two 3mm Phillips #1 screws and lift the board from the pegs.
    • Remove the board from the laptop.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 591
