Saltar al contenido principal
Dell Wyse Xn0m Battery Replacement
Qué necesitas
  1. Dell Wyse Xn0m Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Identify the location of the battery release switches.
  2. Dell Wyse Xn0m Battery Replacement: paso 2, imagen 1 de 1
    • Slide the left battery release switch to the unlocked position (red showing). This is also indicated by the lock/unlock icons beside the switch.
  3. Dell Wyse Xn0m Battery Replacement: paso 3, imagen 1 de 2 Dell Wyse Xn0m Battery Replacement: paso 3, imagen 2 de 2
    • To remove the battery, pull back the right spring-loaded battery release switch while simultaneously sliding the battery away from the laptop.
    • Reassembly tip: when inserting the new battery, make sure the tracks line up right. The battery tracks should sit on top of the laptop body tracks.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 24
Todo El Tiempo: 1,313
