Partes
No se requieren partes.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the screws that secure the battery to the computer.
    • Remove the screws that secure the battery to the computer.
  6. Lift the battery up and away from the computer.
    • Lift the battery up and away from the computer.
  7. Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
  8. Pull the LED cover toward the keyboard and remove it from the computer.
    • Pull the LED cover toward the keyboard and remove it from the computer.
  9. Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  10. Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
    • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
Linea de Meta
Johnathan Hammond
Miembro Desde 28/02/18
35,941 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 48
