Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the LED Cover.
Partes
No se especificaron partes.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the screws that secure the battery to the computer.
    • Remove the screws that secure the battery to the computer.
  6. Lift the battery up and away from the computer.
    • Lift the battery up and away from the computer.
  7. Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
  8. Pull the LED cover toward the keyboard and remove it from the computer.
    • Pull the LED cover toward the keyboard and remove it from the computer.
Linea de Meta
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 31
