Saltar al contenido principal
Dell Vostro V13 Back Cover and Battery Removal
Qué necesitas
  1. Dell Vostro V13  Back Cover and Battery Removal, Back Cover: paso 1, imagen 1 de 3 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: paso 1, imagen 2 de 3 Dell Vostro V13  Back Cover and Battery Removal, Back Cover: paso 1, imagen 3 de 3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13  Back Cover and Battery Removal: paso 2, imagen 1 de 3 Dell Vostro V13  Back Cover and Battery Removal: paso 2, imagen 2 de 3 Dell Vostro V13  Back Cover and Battery Removal: paso 2, imagen 3 de 3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13  Back Cover and Battery Removal: paso 3, imagen 1 de 3 Dell Vostro V13  Back Cover and Battery Removal: paso 3, imagen 2 de 3 Dell Vostro V13  Back Cover and Battery Removal: paso 3, imagen 3 de 3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13  Back Cover and Battery Removal: paso 4, imagen 1 de 2 Dell Vostro V13  Back Cover and Battery Removal: paso 4, imagen 2 de 2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13  Back Cover and Battery Removal: paso 5, imagen 1 de 3 Dell Vostro V13  Back Cover and Battery Removal: paso 5, imagen 2 de 3 Dell Vostro V13  Back Cover and Battery Removal: paso 5, imagen 3 de 3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13  Back Cover and Battery Removal: paso 6, imagen 1 de 2 Dell Vostro V13  Back Cover and Battery Removal: paso 6, imagen 2 de 2
    • Remove the battery.
    • Removing the battery allows you to work safely.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 34
Todo El Tiempo: 435
