Saltar al contenido principal
Dell Vostro A860 RAM Memory Sticks Replacement
Qué necesitas
  1. Dell Vostro A860 RAM Memory Sticks Replacement, RAM: paso 1, imagen 1 de 2 Dell Vostro A860 RAM Memory Sticks Replacement, RAM: paso 1, imagen 2 de 2
    • With the computer facing down locate the RAM compartment cover.
    • Unscrew the two screws holding the cover to the laptop chassis.
    • The screws do not remove completely, they are clipped into the compartment cover.
    • Lift up on the Memory cover and remove.
  2. Dell Vostro A860 RAM Memory Sticks Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool push outward on both sides of the RAM stick.
    • doing this will release the silver tension clips holding the memory sticks in place. Once released the stick will easily lift up and out of the unit.
Conclusión
Joshua Dennis
Miembro Desde 03/25/16
528 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 415
