Partes
No se requieren partes.
  1. Unlock the battery by sliding the battery-lock latch towards the outer edge.
    • Unlock the battery by sliding the battery-lock latch towards the outer edge.
    • Slide the battery-bay release latch and hold it.
    • Remove the battery from the battery bay.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the two screws from the module cover.
    • Remove the two screws from the module cover.
    • Lift the module cover away from the computer.
  4. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Conclusión
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 15
