Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Battery.
Partes
No se especificaron partes.
  1. Remove the screw that secures the base cover to the computer.
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Remove the screws that secure the base cover to the computer. Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Disconnect the battery cable from its connector on the system board.
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
Linea de Meta
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
36,011 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
930 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 7
Todo El Tiempo: 77
