Introducción
This guide shows how to replace the speakers in the Dell Vostro 5510.
The speakers allow sound to be played out directly from the laptop. If the audio being played begins to crackle or no sound is played when the volume is turned up, the speakers should be replaced.
Qué necesitas
Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
Remove the 4 mm screw from metal plate above the right-side speaker using a Phillips #0 screwdriver.
