Saltar al contenido principal
Dell Vostro 5510 RAM Replacement
Qué necesitas
  1. Dell Vostro 5510 RAM Replacement, Back Cover: paso 1, imagen 1 de 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 RAM Replacement: paso 2, imagen 1 de 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 RAM Replacement: paso 3, imagen 1 de 3 Dell Vostro 5510 RAM Replacement: paso 3, imagen 2 de 3 Dell Vostro 5510 RAM Replacement: paso 3, imagen 3 de 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 RAM Replacement: paso 4, imagen 1 de 3 Dell Vostro 5510 RAM Replacement: paso 4, imagen 2 de 3 Dell Vostro 5510 RAM Replacement: paso 4, imagen 3 de 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 RAM Replacement, RAM: paso 5, imagen 1 de 2 Dell Vostro 5510 RAM Replacement, RAM: paso 5, imagen 2 de 2
    • Locate the memory board.
    • Lift the Mylar to access the memory board.
  6. Dell Vostro 5510 RAM Replacement: paso 6, imagen 1 de 2 Dell Vostro 5510 RAM Replacement: paso 6, imagen 2 de 2
    • Pull the securing clips from both sides of the memory module outwards until the memory board pops up.
    • Remove the memory board from the memory-module slot.
Conclusión
J'Ara Johnson
Miembro Desde 02/09/23
85 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 38
Todo El Tiempo: 241
