Saltar al contenido principal
Dell Vostro 5510 Battery Replacement
Qué necesitas
  1. Dell Vostro 5510 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Battery Replacement: paso 3, imagen 1 de 3 Dell Vostro 5510 Battery Replacement: paso 3, imagen 2 de 3 Dell Vostro 5510 Battery Replacement: paso 3, imagen 3 de 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Battery Replacement: paso 4, imagen 1 de 3 Dell Vostro 5510 Battery Replacement: paso 4, imagen 2 de 3 Dell Vostro 5510 Battery Replacement: paso 4, imagen 3 de 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
  6. Dell Vostro 5510 Battery Replacement: paso 6, imagen 1 de 3 Dell Vostro 5510 Battery Replacement: paso 6, imagen 2 de 3 Dell Vostro 5510 Battery Replacement: paso 6, imagen 3 de 3
    • Lift the battery to remove it
Conclusión
Una persona más ha completado esta guía.
Abril Alejos
Miembro Desde 02/09/23
85 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 21
Todo El Tiempo: 716
