Saltar al contenido principal
Dell Vostro 5510 Back Cover Replacement
Qué necesitas
  1. Dell Vostro 5510 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Back Cover Replacement: paso 2, imagen 1 de 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Back Cover Replacement: paso 3, imagen 1 de 3 Dell Vostro 5510 Back Cover Replacement: paso 3, imagen 2 de 3 Dell Vostro 5510 Back Cover Replacement: paso 3, imagen 3 de 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Back Cover Replacement: paso 4, imagen 1 de 3 Dell Vostro 5510 Back Cover Replacement: paso 4, imagen 2 de 3 Dell Vostro 5510 Back Cover Replacement: paso 4, imagen 3 de 3
    • Lift the cover to remove it from the rest of the laptop.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 390
