Partes
No se requieren partes.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Pry the base cover along the edges to loosen it.
    • Pry the base cover along the edges to loosen it.
  3. Lift and remove the base cover from the computer.
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Disconnect the battery cable from its connector on the system board.
    • Disconnect the battery cable from its connector on the system board.
  6. Release the tabs that secure the battery in the battery bay.
    • Release the tabs that secure the battery in the battery bay.
  7. Lift and remove the battery from the computer.
    • Lift and remove the battery from the computer.
  8. Pry the retention clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
    • Pry the retention clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 87
