Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Partes
No se requieren partes.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Pry the base cover along the edges to loosen it.
    • Pry the base cover along the edges to loosen it.
  3. Lift and remove the base cover from the computer.
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Disconnect the battery cable from its connector on the system board.
    • Disconnect the battery cable from its connector on the system board.
  6. Release the tabs that secure the battery in the battery bay.
    • Release the tabs that secure the battery in the battery bay.
  7. Lift and remove the battery from the computer.
    • Lift and remove the battery from the computer.
  8. Lift the hard drive assembly in an upward direction to release it from its compartment on the computer. Remove the hard drive from the computer.
    • Lift the hard drive assembly in an upward direction to release it from its compartment on the computer. Remove the hard drive from the computer.
  9. Remove the screws that secure the hard drive to the hard drive assembly.
    • Remove the screws that secure the hard drive to the hard drive assembly.
    • Lift and remove the hard drive from the hard drive assembly.
Linea de Meta
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 29
Todo El Tiempo: 363
