Saltar al contenido principal
Introducción
In this guide, will be showing you how to remove and replace the Memory Module.
Partes
No se especificaron partes.
  1. Slide the battery release latch toward the side of the computer until it is engaged.
    • Slide the battery release latch toward the side of the computer until it is engaged.
    • Slide the battery out of the bay.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
    • Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
  4. NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Linea de Meta
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 23
