Partes
No se requieren partes.
  1. Slide the release latches to unlock the battery.
    • Slide the release latches to unlock the battery.
  2. Slide the battery out of the chassis and remove it from the computer.
    • Slide the battery out of the chassis and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Loosen the screws that secure the memory door.
    • Loosen the screws that secure the memory door.
  5. Pry up the memory door near the screw hole, lift, and remove it
    • Pry up the memory door near the screw hole, lift, and remove it
  6. Pry the retention clips away from the memory module until it pops up.
    • Pry the retention clips away from the memory module until it pops up.
  7. Remove the memory module from its connector on the system board.
    • Remove the memory module from its connector on the system board.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 54
