Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. Slide the release latches to unlock the battery.
    • Slide the release latches to unlock the battery.
  2. Slide the battery out of the chassis and remove it from the computer.
    • Slide the battery out of the chassis and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Loosen the screws that secure the memory door.
    • Loosen the screws that secure the memory door.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Pry up the memory door near the screw hole, lift, and remove it
    • Pry up the memory door near the screw hole, lift, and remove it
  6. Remove the screws that secure the hard-drive bracket.
    • Remove the screws that secure the hard-drive bracket.
  7. Slide the hard drive module in the direction shown in the image below.
    • Slide the hard drive module in the direction shown in the image below.
  8. Remove the hard drive module from the system board.
    • Remove the hard drive module from the system board.
  9. Remove the screws that secure the hard-drive bracket.
  10. Slide the hard drive from the hard-drive bracket.
    • Slide the hard drive from the hard-drive bracket.
Linea de Meta
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 8
Últimos 30 Días: 31
Todo El Tiempo: 338
