Partes
No se requieren partes.
  1. Flip the computer over.
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Slide the other battery release latch to the unlock position.
    • Slide the other battery release latch to the unlock position.
  3. Slide the battery and remove it from the computer.
    • Slide the battery and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  6. Lift up the base cover and remove it from the computer.
    • Lift up the base cover and remove it from the computer.
  7. Remove the screw that secures the hard-drive assembly to the computer.
    • Remove the screw that secures the hard-drive assembly to the computer.
  8. Slide the hard-drive assembly towards the center of the computer and lift it up and away from the computer.
    • Slide the hard-drive assembly towards the center of the computer and lift it up and away from the computer.
  9. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  10. Lift up the hard-drive bracket and remove it from the hard-drive assembly
    • Lift up the hard-drive bracket and remove it from the hard-drive assembly
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,756 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 29
