Introducción
In this guide, we will be showing you how to remove and replace the Memory Module.
Partes
No se requieren partes.
  1. Slide the release latch outwards to unlock the battery.
    • Slide the release latch outwards to unlock the battery.
  2. Remove the battery from the computer.
    • Remove the battery from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the screws that secure the access panel to the computer.
    • Remove the screws that secure the access panel to the computer.
    • Lift the access panel partially at a 45–degree angle.
  5. Remove the access panel from the computer.
    • Remove the access panel from the computer.
  6. Pry the securing clips away from the memory module until it pops up.
    • Pry the securing clips away from the memory module until it pops up.
    • Remove the memory module from its socket on the system board.
Linea de Meta
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 34
