Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Partes
No se requieren partes.
  1. Slide the release latch outwards to unlock the battery.
    • Slide the release latch outwards to unlock the battery.
  2. Remove the battery from the computer.
    • Remove the battery from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Remove the screws that secure the access panel to the computer.
    • Remove the screws that secure the access panel to the computer.
    • Lift the access panel partially at a 45–degree angle.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the access panel from the computer.
    • Remove the access panel from the computer.
  6. Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
    • Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
    • Remove the screws that secure the hard drive to the computer.
  7. Lift the hard drive to remove it from the computer [1,2].
    • Lift the hard drive to remove it from the computer [1,2].
  8. Remove the screws that secure the hard drive to the bracket.
    • Remove the screws that secure the hard drive to the bracket.
    • Lift the hard drive from the bracket.
Linea de Meta
Johnathan Hammond
Miembro Desde 28/02/18
35,756 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 7
Últimos 30 Días: 11
Todo El Tiempo: 86
