Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. Slide the release latches to unlock the battery.
    • Slide the release latches to unlock the battery.
  2. Slide the battery and remove it from the computer.
    • Slide the battery and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Remove the screws that secure the access panel to the base of the computer.
    • Remove the screws that secure the access panel to the base of the computer.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Lift the access panel up at an angle and remove it from the computer.
    • Lift the access panel up at an angle and remove it from the computer.
  6. Remove the screws that secure the hard drive to the system.
    • Remove the screws that secure the hard drive to the system.
  7. Lift up the hard drive at an angle from the system and remove.
    • Lift up the hard drive at an angle from the system and remove.
  8. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
Linea de Meta
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 55
