Saltar al contenido principal
Dell Vostro 3510 Display Replacement
Qué necesitas
  1. Dell Vostro 3510 Display Replacement, Display: paso 1, imagen 1 de 2 Dell Vostro 3510 Display Replacement, Display: paso 1, imagen 2 de 2
    • Ensure the laptop is powered off.
    • Flip the laptop over.
  2. Dell Vostro 3510 Display Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Use a Phillips #0 screwdriver to remove the six 1 mm screws (circled in red).
    • Loosen the two captive 1 mm screws on the back corners.
    • Keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
  3. Dell Vostro 3510 Display Replacement: paso 3, imagen 1 de 2 Dell Vostro 3510 Display Replacement: paso 3, imagen 2 de 2
    Metal Spudger
    $2.99
    Comprar
    • Open up the back cover of the laptop.
    • It is much easier to open up the laptop with any type of metal spudger or with Jimmy.
  4. Dell Vostro 3510 Display Replacement: paso 4, imagen 1 de 3 Dell Vostro 3510 Display Replacement: paso 4, imagen 2 de 3 Dell Vostro 3510 Display Replacement: paso 4, imagen 3 de 3
    • Start by unplugging the cable for display.
  5. Dell Vostro 3510 Display Replacement: paso 5, imagen 1 de 3 Dell Vostro 3510 Display Replacement: paso 5, imagen 2 de 3 Dell Vostro 3510 Display Replacement: paso 5, imagen 3 de 3
    • Remove the 1 mm screws in red circle with Phillips #0 screwdriver.
  6. Dell Vostro 3510 Display Replacement: paso 6, imagen 1 de 2 Dell Vostro 3510 Display Replacement: paso 6, imagen 2 de 2
    • Remove the 1 mm screws holding down the metal bracket in red circle with Phillips #0 screwdriver.
  7. Dell Vostro 3510 Display Replacement: paso 7, imagen 1 de 2 Dell Vostro 3510 Display Replacement: paso 7, imagen 2 de 2
    • Unplug both the white and black wire
    • The black wire is marked in red.
    • The white wire is marked in orange.
  8. Dell Vostro 3510 Display Replacement: paso 8, imagen 1 de 3 Dell Vostro 3510 Display Replacement: paso 8, imagen 2 de 3 Dell Vostro 3510 Display Replacement: paso 8, imagen 3 de 3
    • Lift up the hinges circled in red.
  9. Dell Vostro 3510 Display Replacement: paso 9, imagen 1 de 2 Dell Vostro 3510 Display Replacement: paso 9, imagen 2 de 2
    • Hold it at a angle and then it should slide off.
Conclusión
Jhoan Cruz
Miembro Desde 02/01/24
483 Reputación
3 Guías creadas
Equipo
Gateway, Team 16-1, Gonzalez Spring 2024 Miembro de Gateway, Team 16-1, Gonzalez Spring 2024
GCC-GONZALEZ-S24S16G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 42
Todo El Tiempo: 52
