Introducción
In this guide, we will show you how to remove and replace the Memory Module.
Partes
No se requieren partes.
  1. Slide the battery latches to release the battery.
    • Slide the battery latches to release the battery.
  2. Lift and remove the battery from the computer.
    • Lift and remove the battery from the computer.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the screw(s) that secures the cover to the computer. Lift the cover upwards.
    • Remove the screw(s) that secures the cover to the computer. Lift the cover upwards.
  5. Slide the cover outwards to release it from the notches on the computer.
    • Slide the cover outwards to release it from the notches on the computer.
  6. Lift the cover upwards and away from the computer.
    • Lift the cover upwards and away from the computer.
  7. Pry the retention clips away from the memory module until it pops-up. Lift and remove the memory module from its connector.
    • Pry the retention clips away from the memory module until it pops-up. Lift and remove the memory module from its connector.
Conclusión
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 32
