Introducción
In this guide, we will be showing you how to remove and replace the Battery.
Partes
No se requieren partes.
  1. Remove the screw that secures the access panel to the computer.
    • Remove the screw that secures the access panel to the computer.
  2. Remove the access panel from the computer.
    • Remove the access panel from the computer.
  3. Remove the screw that secures the keyboard to the chassis.
    • Remove the screw that secures the keyboard to the chassis.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  6. Flip the keyboard over and lay it on the palmrest.
    • Flip the keyboard over and lay it on the palmrest.
  7. Lift the clip to release the keyboard cable and disconnect it from the computer.
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  8. Disconnect the battery cable from the system board.
    • Disconnect the battery cable from the system board.
  9. Remove the screws that secure the battery to the system board.
    • Remove the screws that secure the battery to the system board.
  10. Remove the battery from the computer.
    • Remove the battery from the computer.
Linea de Meta
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,756 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 31
Todo El Tiempo: 464
