Introducción
In this guide, we will show you how to remove and replace the Memory Module.
Partes
No se requieren partes.
  1. Slide the release latches to unlock the battery.
    • Slide the release latches to unlock the battery.
  2. Slide the battery and remove it from the computer.
    • Slide the battery and remove it from the computer.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the screws that secures the access panel to the base of the computer.
    • Remove the screws that secures the access panel to the base of the computer.
  5. Lift the access panel up at an angle and remove it from the computer.
    • Lift the access panel up at an angle and remove it from the computer.
  6. Pry the retention clips away from the memory module until it pops up.
    • Pry the retention clips away from the memory module until it pops up.
  7. Remove the memory module from its connector on the system board.
    • Remove the memory module from its connector on the system board.
Linea de Meta
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 28
